Zum Hauptinhalt wechseln
How to Replace the Suction Cups for the Anti-Clamp
  1. How to Replace the Suction Cups for the Anti-Clamp, Suction cup information: Schritt 1, Bild 1 von 2 How to Replace the Suction Cups for the Anti-Clamp, Suction cup information: Schritt 1, Bild 2 von 2
    • The suction cups are secured to the clamp by friction-fit pins.
    • To remove the pins, you have to push them through their indents in the clamp's arms.
  2. How to Replace the Suction Cups for the Anti-Clamp, Remove the suction cups: Schritt 2, Bild 1 von 3 How to Replace the Suction Cups for the Anti-Clamp, Remove the suction cups: Schritt 2, Bild 2 von 3 How to Replace the Suction Cups for the Anti-Clamp, Remove the suction cups: Schritt 2, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Clampy - Anti-Clamp
    $24.95
    • Rotate the suction cup towards the indentation in the clamp's arm to release the pin.
    • You may need to use significant force and another hand to support the Anti-Clamp.
    • Remove the suction cup and its pin.
    • During reassembly, angle the pin into the hole across from the indent before pushing it back into the arm.
  3. How to Replace the Suction Cups for the Anti-Clamp, Remove the pin: Schritt 3, Bild 1 von 3 How to Replace the Suction Cups for the Anti-Clamp, Remove the pin: Schritt 3, Bild 2 von 3 How to Replace the Suction Cups for the Anti-Clamp, Remove the pin: Schritt 3, Bild 3 von 3
    • Pull the pin through the top of the suction cup and remove it.
Abschluss
For other general electronics skills guides, click here.
2 weitere Personen haben diese Anleitung absolviert.
Alex Diaz-Kokaisl
212.632 Reputation
1.039 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
23.608 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 40
Insgesamt: 1,175
