Einleitung
A rim can be out of round in the radial or axial direction. A wheel truing stand is helpful but not a necessity. When tightening the spokes on one side of the wheel, remember to loosen the opposite spokes the same amount so they don't become over tightened.
Was du brauchst
Fit the wheel into the wheel truing stand. It doesn't matter which way the wheel is facing.
Bring the calipers up until the teeth are are about half an inch from the metal rim of the wheel.
Start the wheel spinning slowly.
Slowly tighten the calipers until they contact the wheel on one side or the other.
Loosen the spoke nipples that attach to the same side of the wheel that the caliper is touching. At the same time, tighten the spokes that attach to the opposite side of the hub.
As a starting point, turn all the spokes half of a turn for each of the spokes near the caliper contact point.
Spin the wheel. Tighten the calipers again until they touch the rim on only one side at a time at certain point. Repeat steps 2-3 until the caiplers touch both sides of the rim evenly at every point on the rim.
The wheel should spin without wobbling from side to side or wavering up and down
2 weitere Personen haben diese Anleitung absolviert.
