Zum Hauptinhalt wechseln
How to clean the CONDOR L130I3E fan
Einführungsvideo
  1. How to clean the CONDOR L130I3E fan, How to clean the CONDOR L130I3E fan: Schritt 1, Bild 1 von 3 How to clean the CONDOR L130I3E fan, How to clean the CONDOR L130I3E fan: Schritt 1, Bild 2 von 3 How to clean the CONDOR L130I3E fan, How to clean the CONDOR L130I3E fan: Schritt 1, Bild 3 von 3
    • First of all, make sure your device is switched off and unplugged.
    • Remove the battery by pulling the two screws in the direction indicated by the pins.
    • Pull the battery up.
  2. How to clean the CONDOR L130I3E fan: Schritt 2, Bild 1 von 3 How to clean the CONDOR L130I3E fan: Schritt 2, Bild 2 von 3 How to clean the CONDOR L130I3E fan: Schritt 2, Bild 3 von 3
    • To remove the hard drive, unplug its screws in this cover.
    • Pull the hard drive in the direction indicated to remove it.
    • Then we remove the hard drive from its place with ease.
  3. How to clean the CONDOR L130I3E fan: Schritt 3, Bild 1 von 3 How to clean the CONDOR L130I3E fan: Schritt 3, Bild 2 von 3 How to clean the CONDOR L130I3E fan: Schritt 3, Bild 3 von 3
    • To access the motherboard, you must first remove the keyboard because underneath it screws should be removed to separate the base of the chassis from the top of the keyboard.
    • With a flat screwdriver we remove the keyboard by pressing the red-pointed component and pushing the keyboard up to release it.
  4. How to clean the CONDOR L130I3E fan: Schritt 4, Bild 1 von 2 How to clean the CONDOR L130I3E fan: Schritt 4, Bild 2 von 2
    • Remove the keyboard connector from the motherboard
    • Keyboard is now removed successfully
  5. How to clean the CONDOR L130I3E fan: Schritt 5, Bild 1 von 3 How to clean the CONDOR L130I3E fan: Schritt 5, Bild 2 von 3 How to clean the CONDOR L130I3E fan: Schritt 5, Bild 3 von 3
    • Remove the top cover and remove the processor cooling fan.
    • Unscrew the screws indicated in red to remove the cooling fan.
    • Remove the fan.
  6. How to clean the CONDOR L130I3E fan: Schritt 6, Bild 1 von 1
    • We now clean and remove the dust and sediments that hinder fan function and increase processor heat.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
fr en
100%
Hier starten ›
AMOUR nasreddine
1.107 Reputation
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 799
