Was du brauchst
First we need to take off the face plate.
Use the tweezers to put the rubber belt back on the 2 pulleys we took them off of.
I have found it is easier to start with the big pulley first then once around the big pulley get the belt around the small belt.
Close the DVD Drive and put the face plate back on.
Plug the system in and test to see if the drive works.
These steps have helped me fix 2 original Xbox systems and 3 Xbox 360 systems. I hope it helps yall. If you need any clarification on any of the steps please message me.
15 weitere Nutzer:innen haben diese Anleitung absolviert.
8 Kommentare
the picture of the exbox is not mine
the picture you show is not my console
It had to use different tools to open and clean the rubber pulley with 70% Alcohol. Thank you for posting it i fixed my 2009 Black xbox 360 Console.
How did you open your Xbox? Because mine also doesn’t have that hole
Astr0 -
