Einleitung
This guide will show you how to repair your 1984-1989 Toyota 4Runner / Truck’s ECU’s return to battery cable. Sometimes while off-roading the battery can come loose, which can then tug on the ECU’s return to battery cable. If this cable is severed, the truck will not run.
View this How To Guide on soldering if you need any more tips for this part of the guide.
Was du brauchst
Disconnect the ECU and positive cable by using your 12mm wrench to loosen the bolt on the battery's positive terminal.
Once the cables are disconnected, place the positive cable out of the way.
Place a piece of cardboard on top of the battery to work on.
Peel the black electrical tape off of the ECU wire.
Spread the individual wires apart in each cable.
Then mesh the ends of the cables together.
Pinch down on the meshed cable ends.
Plug your soldering iron in to let it warm up.
Tape the white cable to the cardboard so that the cables don't move around while you're working.
Take your shrink wrap, and wrap it around the cable.
Use a hair dryer to blast the shrink wrap with heat. Move the dryer up and down over the wrap.
Wrap a few layers of electrical tape over the heat shrink tubing.
Work your way up the cable and cut the tape once you've reached the top.
Once more tape the cable starting a few inches below the solder and work your way back to the top. Cut the tape again.
Place the positive cable down first.
Then place a washer between the cables.
Place the ECU cable, then one final washer, and finally tighten the bolt on top.
To reassemble your device, besure to place the positive cable down first. Then place a washer between the cables. Place the last washer on top of the ECU cable, then bolt down.
Ein Kommentar
Hello ; I need help fixing my ECU it over heats and disconnects the data lines from the other computers in the car leading it to not start or start and fail and I cannot replace it without the data on the original ECU
If anyone knows a trick on how to copy the data from the ecu or fix the power issue please feel free to contact me at amd13@windowslive.com or via mobile+9665633330544
Regards
Ali Al Dawood
And thanks for the tips they were helpful I managed to shift gears but not start the car
Much appreciated
