Zum Hauptinhalt wechseln
Hydraulic Fluid Draining
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. Hydraulic Fluid Draining, Disconnect the spark plug wire: Schritt 1, Bild 1 von 2 Hydraulic Fluid Draining, Disconnect the spark plug wire: Schritt 1, Bild 2 von 2
    • Before you begin, ensure that the engine is powered down and cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Hydraulic Fluid Draining, Flip the engine switch to the off position: Schritt 2, Bild 1 von 2 Hydraulic Fluid Draining, Flip the engine switch to the off position: Schritt 2, Bild 2 von 2
    • Flip the red engine ON/OFF switch to the OFF position.
  3. Hydraulic Fluid Draining, Close the fuel valve: Schritt 3, Bild 1 von 2 Hydraulic Fluid Draining, Close the fuel valve: Schritt 3, Bild 2 von 2
    • Flip the fuel valve lever to the OFF position.
  4. Hydraulic Fluid Draining, Turn off the ignition: Schritt 4, Bild 1 von 2 Hydraulic Fluid Draining, Turn off the ignition: Schritt 4, Bild 2 von 2
    • Flip the ignition switch to the OFF position.
    • Ensure the wheel drive control lever is set to the neutral position.
  5. Hydraulic Fluid Draining, Allow the wheels to freewheel: Schritt 5, Bild 1 von 3 Hydraulic Fluid Draining, Allow the wheels to freewheel: Schritt 5, Bild 2 von 3 Hydraulic Fluid Draining, Allow the wheels to freewheel: Schritt 5, Bild 3 von 3
    • Pull the locking pin out and rotate it 90˚ to unlock the right wheel from the hub.
    • Repeat for the left wheel.
  6. Hydraulic Fluid Draining, Add wheel chocks: Schritt 6, Bild 1 von 1
    • Insert wheel chocks underneath each wheel to keep the device stationary during disassembly.
  7. Hydraulic Fluid Draining, Remove the fill plug: Schritt 7, Bild 1 von 1
    • Use a 14 mm hex key to remove the tank fill plug.
  8. Hydraulic Fluid Draining, Remove the fluid: Schritt 8, Bild 1 von 1
    • Use a siphon to pump out as much fluid as you're able to, totaling about 14 gallons.
Abschluss
Carsten Frauenheim
136.505 Reputation
371 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
118 Mitglieder
19.637 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 12
