Zum Hauptinhalt wechseln
IQ America VD-8810L Motherboard Replacement
Was du brauchst
  1. IQ America VD-8810L Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 3 IQ America VD-8810L Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 3 IQ America VD-8810L Motherboard Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Wedge the spudger into the slot of the panel on the bottom of the device.
    • Rotate out the panel to reveal the screw holding the device together.
  2. IQ America VD-8810L Motherboard Replacement: Schritt 2, Bild 1 von 2 IQ America VD-8810L Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Use the Phillips head screwdriver to remove the screw.
    • Separate the Top and bottom halves of the device.
  3. IQ America VD-8810L Motherboard Replacement: Schritt 3, Bild 1 von 3 IQ America VD-8810L Motherboard Replacement: Schritt 3, Bild 2 von 3 IQ America VD-8810L Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Remove batteries from the battery slot.
    • Unscrew the two Phillips head screws in the center of the battery slot.
    • Unscrew the remaining two screws at the bottom of the unit using the 3.0 triangle head screwdriver.
  4. IQ America VD-8810L Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Use the spudger to separate the top and bottom halves of the screen.
  5. IQ America VD-8810L Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the wires from the green motherboard to the bottom half by pulling apart the connecting pins.
  6. IQ America VD-8810L Motherboard Replacement: Schritt 6, Bild 1 von 3 IQ America VD-8810L Motherboard Replacement: Schritt 6, Bild 2 von 3 IQ America VD-8810L Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Unscrew all 3 Phillips head screws on the outside edges of the motherboard.
  7. IQ America VD-8810L Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Carefully remove the microphone from the casing by pulling away from the device.
  8. IQ America VD-8810L Motherboard Replacement: Schritt 8, Bild 1 von 2 IQ America VD-8810L Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Gently lift the motherboard from the casing to reveal the speaker.
    • Unscrew the two Phillips head screws that hold the speaker in place.
  9. IQ America VD-8810L Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Refer to this guide to desolder the speaker from the motherboard.
Abschluss
Jackey Lau
301 Reputation
3 Anleitungen geschrieben
UC Santa Barbara, Team S1-G3, Weedon Fall 2017 Mitglied von UC Santa Barbara, Team S1-G3, Weedon Fall 2017
UCSB-WEEDON-F17S1G3
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 243
