Zum Hauptinhalt wechseln
Infant Optics DXR-8 Monitor Motherboard Replacement
Was du brauchst
  1. Infant Optics DXR-8 Monitor Motherboard Replacement, Internal Monitor Components: Schritt 1, Bild 1 von 3 Infant Optics DXR-8 Monitor Motherboard Replacement, Internal Monitor Components: Schritt 1, Bild 2 von 3 Infant Optics DXR-8 Monitor Motherboard Replacement, Internal Monitor Components: Schritt 1, Bild 3 von 3
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Monitor Motherboard Replacement: Schritt 2, Bild 1 von 3 Infant Optics DXR-8 Monitor Motherboard Replacement: Schritt 2, Bild 2 von 3 Infant Optics DXR-8 Monitor Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Monitor Motherboard Replacement: Schritt 3, Bild 1 von 3 Infant Optics DXR-8 Monitor Motherboard Replacement: Schritt 3, Bild 2 von 3 Infant Optics DXR-8 Monitor Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Disconnect speaker from monitor for ease of access by unplugging wire.
  4. Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Screen: Schritt 4, Bild 1 von 3 Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Screen: Schritt 4, Bild 2 von 3 Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Screen: Schritt 4, Bild 3 von 3
    • Using a plastic opening tool, disconnect the ribbon cable connector.
    • Gently separate the ribbon cable from the motherboard.
  5. Infant Optics DXR-8 Monitor Motherboard Replacement: Schritt 5, Bild 1 von 2 Infant Optics DXR-8 Monitor Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Using a Phillips #000 screwdriver, remove the four 4mm screws around the edge of the motherboard.
    • Flip the motherboard away from the front case to reveal the screen on the other side.
  6. Infant Optics DXR-8 Monitor Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Using a plastic opening tool, carefully pry the top retaining frame off of the screen. Start in one corner and work around the bottom of the frame.
  7. Infant Optics DXR-8 Monitor Motherboard Replacement: Schritt 7, Bild 1 von 3 Infant Optics DXR-8 Monitor Motherboard Replacement: Schritt 7, Bild 2 von 3 Infant Optics DXR-8 Monitor Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Using a plastic opening pick, carefully pry a corner of the screen away from the motherboard.
    • Lift the screen off of the motherboard.
  8. Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Motherboard: Schritt 8, Bild 1 von 2 Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Motherboard: Schritt 8, Bild 2 von 2
    • Flip the motherboard away from the case.
    • Using a soldering iron and desoldering braid, desolder the antenna from the motherboard.
    • For more information on soldering, please visit the How to Solder and Desolder Connections guide.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
2 Kommentare
Can you do one for the DXR-8 Pro monitor? Mine randomly stoped turning on and I want to see if I can open it up and try to fix it.
Andfel - Antwort
Can you please tell me where to buy a replacement motherboard??
Ilya Nechay - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 30
Insgesamt: 1,102
