Zum Hauptinhalt wechseln
Insignia Flex 10.1 Motherboard Replacement
Was du brauchst
  1. Insignia Flex 10.1 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Please be aware that removing the rear panel from the back of the Flex 10.1 may cause damage to the rear panel.
  2. Insignia Flex 10.1 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • The rear panel is secured to the front case by 26 clips attached to the rear panel. These clips lock onto small tabs machined into the front case.
    • To free the tabs, they must be pushed toward the center of the device. When using the plastic opening tool to free the rear panel, be sure to work the tool at the location of these clips.
    • Remove back cover by inserting a plastic opening tool along the edge of the device to release the clips.
  3. Insignia Flex 10.1 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Opening the Flex 10.1 can be challenging. Don't get discouraged if it takes multiple attempts before the Flex 10.1 is opened.
    • Insert the plastic opening tool into the seam between the front case and the rear panel of the Flex 10.1.
    • Gently enlarge the existing gap by pressing and wiggling the plastic opening tool into the gap near each of the clips attached to the rear case, pushing the clips toward the center of the device until the clips have been freed.
    • Repeat the same procedure to free all clips around the Flex 10.1.
  4. Insignia Flex 10.1 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • After ensuring all clips are free, separate the two halves of the Flex 10.1.
    • The rear panel is now free from the Flex 10.1.
  5. Insignia Flex 10.1 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • With the rear panel removed, the back side of the Flex 10.1 should look like this.
  6. Insignia Flex 10.1 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Peel off the tape covering the two connections labeled in orange.
  7. Insignia Flex 10.1 Motherboard Replacement: Schritt 7, Bild 1 von 3 Insignia Flex 10.1 Motherboard Replacement: Schritt 7, Bild 2 von 3 Insignia Flex 10.1 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Remove the ribbon cable by lifting up on the connection with a plastic opening tool and pulling out the ribbon cable.
  8. Insignia Flex 10.1 Motherboard Replacement: Schritt 8, Bild 1 von 3 Insignia Flex 10.1 Motherboard Replacement: Schritt 8, Bild 2 von 3 Insignia Flex 10.1 Motherboard Replacement: Schritt 8, Bild 3 von 3
  9. Insignia Flex 10.1 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Those who are new to soldering may want to check out iFixit's soldering technique guide. Wie man Lötverbindungen herstellt und entlötet.
    • Unsolder the 18 solder joints labeled in GREEN in the picture. Begin by heating up each solder joint on the motherboard.
    • When the solder melts and the wire is free from the motherboard, immediately lift the solder tip off the connection to avoid damage.
    • Due to the fragile nature of electronic components, it is important to limit the amount of heat transferred from the soldering iron to the motherboard. A simple way to accomplish this is to pull the wires with gentle continuous tension while the soldering iron heats up the connection.
  10. Insignia Flex 10.1 Motherboard Replacement: Schritt 10, Bild 1 von 2 Insignia Flex 10.1 Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Use a Phillips head #0 screwdriver to unscrew the 5 philips head screws labeled in BLUE.
  11. Insignia Flex 10.1 Motherboard Replacement: Schritt 11, Bild 1 von 2 Insignia Flex 10.1 Motherboard Replacement: Schritt 11, Bild 2 von 2
    • The motherboard is now free. Lift the motherboard with your hands or a plastic opening tool.
    • The motherboard can now be replaced.
  12. Insignia Flex 10.1 Motherboard Replacement: Schritt 12, Bild 1 von 1
    • The motherboard is now free and should look like this.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team 2-1, Isaacson Spring 2016 Mitglied von UMass Dartmouth, Team 2-1, Isaacson Spring 2016
UMASSD-ISAACSON-S16S2G1
3 Mitglieder
11 Anleitungen geschrieben
3 Kommentare
You're replacing the mother board, and yet you CUT all the wires coming into the motherboard. Now to put a new mother board on, you'll have replace the wires you cut. The proper thing would be to de-solder the wires off the motherboard, leaving them intact to reconnect to the new board.
joelniergarth - Antwort
your so right
steve -
Where can you get a new motherboard from .
steve -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 12
Insgesamt: 2,142
