Zum Hauptinhalt wechseln
Insignia Flex 10.1 NS-P10A6100 Battery Replacement
Was du brauchst
  1. Insignia Flex 10.1 NS-P10A6100 Battery Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Make sure your tablet is turned off and not connected to a power source to prevent personal injury.
    • The volume rocker and power button located on the top edge by the camera are not connected pieces and will become free from the device once the front panel is removed from the back case. They are easily put back in place when reassembling the tablet.
    • Position the tablet with the top edge by the camera facing down.
    • Insert the plastic opening tool between the front panel and back case at the upper left hand corner of the tablet.
    Frag FixBot
    Kommentar hinzufügen
  2. Insignia Flex 10.1 NS-P10A6100 Battery Replacement: Schritt 2, Bild 1 von 2 Insignia Flex 10.1 NS-P10A6100 Battery Replacement: Schritt 2, Bild 2 von 2
    • Slide the plastic opening tool along the edge of the tablet between the front panel and back case.
    • Repeat this process for the two shorter edges of the tablet leaving the top edge by the camera still snapped in place.
    Frag FixBot
  3. Insignia Flex 10.1 NS-P10A6100 Battery Replacement: Schritt 3, Bild 1 von 1
    • Using an unfolding motion along the top edge of the tablet, carefully separate the front panel from the back case.
    Frag FixBot
  4. Insignia Flex 10.1 NS-P10A6100 Battery Replacement, Battery: Schritt 4, Bild 1 von 1
    • Using the plastic opening tool, lift up the black retaining flap that secures the ZIF (zero insertion force) ribbon connector over the battery to the motherboard.
    Frag FixBot
  5. Insignia Flex 10.1 NS-P10A6100 Battery Replacement: Schritt 5, Bild 1 von 1
    • Pull the ZIF (zero insertion force) ribbon connector out from underneath the black retaining flap.
    Frag FixBot
  6. Insignia Flex 10.1 NS-P10A6100 Battery Replacement: Schritt 6, Bild 1 von 3 Insignia Flex 10.1 NS-P10A6100 Battery Replacement: Schritt 6, Bild 2 von 3 Insignia Flex 10.1 NS-P10A6100 Battery Replacement: Schritt 6, Bild 3 von 3
    • Using the plastic opening tool, remove the black tape that secures the battery to the front panel.
    • Repeat this process for the black tape securing the other side of the battery to the front panel.
    Frag FixBot
  7. Insignia Flex 10.1 NS-P10A6100 Battery Replacement: Schritt 7, Bild 1 von 1
    • Desoldering can cause fumes that are dangerous to breathe in, and materials may be hot.
    • Desolder the three joints connecting the red, black, and white wires from the battery to the motherboard.
    • A thorough guide including step by step instructions on how to solder and desolder can be found here.
    Frag FixBot
  8. Insignia Flex 10.1 NS-P10A6100 Battery Replacement: Schritt 8, Bild 1 von 1
    • Insert the plastic opening tool between the battery and the front panel in the middle of the battery pack.
    Frag FixBot
  9. Insignia Flex 10.1 NS-P10A6100 Battery Replacement: Schritt 9, Bild 1 von 1
    • Be careful not to severely bend the battery or puncture it as it may leak potentially dangerous chemicals. Edit: THE BATTERY CAN EXPLODE AFTER THE LEAK OF FUMES. IF IN ANY KIND OF CONTACT WITH WATER, FROM INSIDE OF BATTERY, THE BATTERY WILL CATCH ON COLOURED FLAME. YES, COLOURED FLAME. IT’S A GOOD EXPERIMENT BUT ONLY IN ADULT SUPERVISION AND SAFETY
    • Using the plastic opening tool, pry the battery from the front panel until there is room to peel it off with your hand.
    • The battery is stuck on to the front panel with adhesive tape, so don't be afraid to use slight force when removing it.
    Frag FixBot
Abschluss
The battery is now free rom the device and can be replaced. To reassemble your device, follow these instructions in reverse order.
6 weitere Personen haben diese Anleitung absolviert.
Baylor, Team 5-8, Williams Fall 2016 Mitglied von Baylor, Team 5-8, Williams Fall 2016
BU-WILLIAMS-F16S5G8
3 Mitglieder
12 Anleitungen geschrieben
4 Kommentare zur Anleitung
great instructions....congratulations...i was able to replace the battery in 10 minutes
coconut1200 - Antwort Teilen
I have an Insignia tablet and the battery is gone and I need to find out how much a battery will be. if it will be worth getting one or replacing the tablet
please let me know what I need to do you can email me at clarklinda10@yahoo.com
clarklinda10 - Antwort Teilen
Necesito el software del la tablet insignia ns14t004, o un software parecido a insignia 10.1.
Por favor, mi correo es adair.saenz01@gmail.com
Adair Saenz - Antwort Teilen
If possible, the battery should be discharged as far as possible to reduce the chance of explosion if the lines are accidentally shorted while de-soldering the lines from the mainboard.
Krista Barron - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 40
Insgesamt: 4,484
