Einleitung
The motherboard replacement also replaces the charging port because they come as 1 component.
Was du brauchst
Place the device on a firm surface with the device screen facing down.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
Using a plastic tool and the plastic card, gently pry off the back cover.
Using tweezers, remove the electrical connector that connects to the battery to remove the power to the battery.
Flip up the black cover pieces to expose the 3 electrical connectors.
Remove 3 electrical connectors by gently pulling back on them with some tweezers.
Unplug the 2 black ground wires from the motherboard by gently prying on them until they unhook from the motherboard.
Remove the black camera connector by gently prying on it until it unhooks.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
This looks great. Can you provide more detail on Step 3 (opening the case?) Are there locking tabs that I need to worry about breaking? And if so, how many? Does the cover simply snap back into place?
I need to open my unit simply to disconnect the power to clear the BIOS. I stupidly disabled my USB ports and there is no way to navigate the BIOS without the (USB) keyboard (how freaking dumb is that!)
Very nicely done. Do you suppose that the SSD can be upgraded to something larger?
