Einleitung
The steps provided will walk you through the necessary replacement for the screen. Complete the prerequisites before performing these tasks.
Was du brauchst
Place the device on a firm surface with the device screen facing down.
Using a plastic tool and the plastic card, gently pry off the back cover.
Using tweezers, remove the electrical connector that connects to the battery to remove the power to the battery.
Flip up the black cover pieces to expose the 3 electrical connectors.
Remove 3 electrical connectors by gently pulling back on them with some tweezers.
Unplug the 2 black ground wires from the motherboard by gently prying on them until they unhook from the motherboard.
Remove the black camera connector by gently prying on it until it unhooks.
Remove 12 - 4.15mm J000 Phillips screws from the metal bracket.
Bracket will then come off.
4 weitere Personen haben diese Anleitung absolviert.
6 Kommentare
The Flex 11.6" Model# NS-P11W7100 DOEST HAVE THOSE SCREWS RIGHT THERE!!!!!
yeah, thats the one I have. its quite a bit different. the speaker wires are soldered, too…
mine doesn’t look like that…
where can i get a new screen to buy?
Do you sell the insignia ns-p11w7100 tablet 11.6 inches screen? I need on to fix my broken part.
