Einleitung
If your JBL Clip 2's built in AUX cord is not playing music from your music device there may be an issue with the cord itself. The device will be taken apart and the audio AUX cord will be removed and replaced.
Was du brauchst
Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
There will be six 3 mm T8 screws under the cap, remove these six screws. Save
If you are not trying to replace the speaker please ignore the two middle 3 mm T8 screws during this procedure.
To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
There will be four 3 mm T8 screws holding the motherboard in place, remove these four screws.
Disconnect the three solder points connecting the AUX cord to the motherboard.
Remove the AUX cord.
3 weitere Personen haben diese Anleitung absolviert.
