Einleitung
The speaker is the main part of the JBL Clip+. This guide will show how to remove this.
Was du brauchst
Use the angled tweezers to carefully pull the rubber bumper off the back side of the device
There will be three 6mm philips head screws under that rubber bumper, remove these three screws.
The battery is adhered to the back cover of the JBL Clip Plus, slowly lift the battery away from the case, using a spudger to pry the battery away from the adhesive.
Use the plastic prying tool to gently remove the face of the speaker from the body.
Use the spudger tool to gently scrape away the adhesive holding in the microphone.
Gently push the motherboard away from the microphone, this will allow you to remove the microphone.
Gently push the motherboard out from the frame of the JBL Clip Plus, this requires some force.
There are three solder points that need to be desoldered.
If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
There are two #1 philips head 4mm screw fastening the speaker to the body, remove these.
Remove the solder on the motherboard.
If you are unsure how to desolder these connections refer to : How To Solder and Desolder Connections
4 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
do you know were can i buy the new speaker for my jbl clip +?
I work in A/V. I frequently need to adjust audio systems.
I want to add a switch to the speaker wire, so I can turn the speaker off, and use the line out port only, in order to test audio systems with a Bluetooth reciver.
I can be at the mixing board, adjusting sliders while the music is playing, with no cables.
Will this work?
