Zum Hauptinhalt wechseln
JBL Tune 510BT Volume Button Replacement
Was du brauchst
  1. JBL Tune 510BT Volume Button Replacement, Faceplate: Schritt 1, Bild 1 von 2 JBL Tune 510BT Volume Button Replacement, Faceplate: Schritt 1, Bild 2 von 2
    • Firmly grasp the earmuff and pull away from the center until the lip of the earmuff is disengaged.
    • Pull the earmuff towards the center of the headphones until it is free.
  2. JBL Tune 510BT Volume Button Replacement: Schritt 2, Bild 1 von 2 JBL Tune 510BT Volume Button Replacement: Schritt 2, Bild 2 von 2
    • Remove the three 3 mm screws using a JIS #00 screwdriver.
  3. JBL Tune 510BT Volume Button Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the faceplate by lifting it firmly.
    • Avoid rough movements, as there is a single thin wire connecting the faceplate to the internals.
    • If the repair is for the right-side driver, be mindful of the charging port, as the faceplate has a slot there for it. Lift the opposite end and back the port out.
    • To completely detach the faceplate, desolder the wires from the connections on the motherboard.
  4. JBL Tune 510BT Volume Button Replacement, Volume Button: Schritt 4, Bild 1 von 2 JBL Tune 510BT Volume Button Replacement, Volume Button: Schritt 4, Bild 2 von 2
    • Remove the 1 mm screw using a JIS #00 screwdriver.
    • Using your finger or a Jimmy, gently pry the circuit board from the casing, being careful to not pull too hard to dislodge the connected wires.
  5. JBL Tune 510BT Volume Button Replacement: Schritt 5, Bild 1 von 3 JBL Tune 510BT Volume Button Replacement: Schritt 5, Bild 2 von 3 JBL Tune 510BT Volume Button Replacement: Schritt 5, Bild 3 von 3
    • Gently push the damaged volume button from the outside towards the inner part of the headphone casing until it dislodges.
    • Replace it with the new button by connecting the tabs at the top and swinging the button into place.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Ryan
513 Reputation
4 Anleitungen geschrieben
Utah Tech University, Team 1-2, McMurrin Spring 2024 Mitglied von Utah Tech University, Team 1-2, McMurrin Spring 2024
UTAHTECH-MCMURRIN-S24S1G2
2 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 12
Letzte 30 Tage: 23
Insgesamt: 46
