Zum Hauptinhalt wechseln
JBL Xtreme battery replacement
Was du brauchst
  1. JBL Xtreme battery replacement, Battery: Schritt 1, Bild 1 von 1
    • 8.4 V battery pack for the JBL Extreme.
  2. JBL Xtreme battery replacement: Schritt 2, Bild 1 von 1
    • Unscrew the screws and remove the shell.
  3. JBL Xtreme battery replacement: Schritt 3, Bild 1 von 1
    • Remove the battery pack by unscrewing the 8 screws. Unplug the battery pack. Drill a hole. Seal holes with hot glue for air-tightness.
  4. JBL Xtreme battery replacement: Schritt 4, Bild 1 von 2 JBL Xtreme battery replacement: Schritt 4, Bild 2 von 2
    • Solder the positive wires together, and solder the negative wires together. Use a 5.5 x 2.1 hollow DC connector for the power supply. Insulate the cable ends (Heat shrink wrap, electrical tape, etc.)
  5. JBL Xtreme battery replacement: Schritt 5, Bild 1 von 1
    • Battery, 8.4 Volt. 13200mAh 8.4V Rechargeable Battery Pack Charger for Bicycle Light-XML-T6
  6. JBL Xtreme battery replacement: Schritt 6, Bild 1 von 1
    • Solarstorm 2S2P 18650 Battery Case.
    • 4xPanasonic NCR18650B 3,7V 3400mAh=14400 mAh
    • + 5V USB ON/OFF Button
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
de en
100%
Hier starten ›
Bert
217 Reputation
1 Anleitung geschrieben
6 Kommentare
hi
step 2: unscrew the screws …. thats th point, where are the screws. the body looks like glued.
stephan dingsda - Antwort
Hi.
Don’t ask me, because I have this guide only translated not created. Try to contact the author on de.ifixit.com. I have translated it so, that I tried to don’t change the original text.
Martin
Martin Kubica - Antwort
I didn’t get it quite clear: is there a original battery replacement or an improvised one? I am interested in replacing mine but I didn’t find the battery.
Chris Fotu - Antwort
Hi.
See the comment higher.
Martin Kubica
WTF?!? Don’t do this. Buy a replacement battery online, and swap it out. Don’t drill holes, add glue, and try to cram in some battery that isn’t built for it!
fixit4 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 31
Letzte 30 Tage: 126
Insgesamt: 27,682
