Einleitung
This guide will show you how to replace the battery on the Freeway.
Was du brauchst
Remove the rubber pads from the bottom of the device using the spudger.
Gently lift the front panel off of the device and carefully rest it to the side.
Desolder the three wires connecting the battery.
Please refer to the soldering technique guide for instructions on desoldering and soldering.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
11 Kommentare
Hi,
Does anyone knows a source for the compatible battery. Since Jabra Freeway battery has 3 wires, cannot find it online. I could find compatible batteries from China websites but they were with 2 wires.
