Einleitung
In this guide you will be replacing the microphone of the Jabra Freeway.
Was du brauchst
Remove the rubber pads from the bottom of the device using the spudger.
Gently lift the front panel off of the device and carefully rest it to the side.
Desolder the two wires connecting to the microphone.
Please refer to the soldering technique guide for instructions on desoldering and soldering.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
2 Kommentare
Perfect, thank you.
Based on my limited experience with this device, the component being replaced here is the secondary, or noise-cancelling microphone - not to be confused with the primary microphone. The other video showing replacement of the motion detector seems to be actually replacing the primary microphone.
