Zum Hauptinhalt wechseln
Jabra Freeway Motion Detector Replacement
Was du brauchst
  1. Jabra Freeway Motion Detector Replacement, Front Panel: Schritt 1, Bild 1 von 3 Jabra Freeway Motion Detector Replacement, Front Panel: Schritt 1, Bild 2 von 3 Jabra Freeway Motion Detector Replacement, Front Panel: Schritt 1, Bild 3 von 3
    • Turn off the device before proceeding. Failure to do so may result in device damage or injury to oneself.
    • Remove the rubber pads from the bottom of the device using the spudger.
  2. Jabra Freeway Motion Detector Replacement: Schritt 2, Bild 1 von 3 Jabra Freeway Motion Detector Replacement: Schritt 2, Bild 2 von 3 Jabra Freeway Motion Detector Replacement: Schritt 2, Bild 3 von 3
    • Remove the eight 6mm T9 screws.
    • Two of these screws are underneath the foam padding. This padding is glued on and will be destroyed in this process. Poking through the foam minimizes the damage to the device.
  3. Jabra Freeway Motion Detector Replacement: Schritt 3, Bild 1 von 3 Jabra Freeway Motion Detector Replacement: Schritt 3, Bild 2 von 3 Jabra Freeway Motion Detector Replacement: Schritt 3, Bild 3 von 3
    • Gently lift the front panel off of the device and carefully rest it to the side.
  4. Jabra Freeway Motion Detector Replacement, Motion Detector: Schritt 4, Bild 1 von 3 Jabra Freeway Motion Detector Replacement, Motion Detector: Schritt 4, Bild 2 von 3 Jabra Freeway Motion Detector Replacement, Motion Detector: Schritt 4, Bild 3 von 3
    • Use the plastic opening tool to lift the motion detector off the circuit board.
    • The motion detector is glued in place, so a moderate amount of force is required.
  5. Jabra Freeway Motion Detector Replacement: Schritt 5, Bild 1 von 1
    • Desolder the two wires connecting the motion detector to the circuit board.
    • Please refer to the soldering technique guide for instructions on desoldering and soldering.
Abschluss
Alec Wilson
741 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 4-8, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 4-8, Catania Fall 2016
UMASSD-CATANIA-F16S4G8
2 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Based on my limited experience with this device, the component being replaced here is the primary microphone - not the motion detector as claimed. The other video showing replacement of the microphone is actually the secondary, or noise-cancelling microphone. I don’t know the exact components for the motion detector, but I’m quite sure that this is not that component.
Steve MacLeod - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 502
