Einleitung
This guide will walk you through the process of replacing the motherboard, to get your tablet working again. This replacement requires soldering skills. Learn more about soldering, here.
Was du brauchst
Pry the back case off using the blue Plastic Opening Tools. Work one along the seem until you can get your fingers under to pull it apart.
Remove the two pieces of tape securing the ribbon cables to the motherboard.
Using a plastic prying tool, lift open the latch that secures the ribbon cable next to the speaker.
Pull the ribbon cable out of its connector on the motherboard.
Use a plastic prying tool to disconnect the other ribbon cable from the motherboard. This cable belongs to the device's cameras.
Disconnect the large ribbon cable from the motherboard. Do this by unlocking the tabs on each side of the connector.
Snip the two sets of wires that are attached to the motherboard. Cut the wires as close to the board as possible. This will leave plenty of length to reattach the wires to the new board.
