Zum Hauptinhalt wechseln
Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement
Was du brauchst
  1. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing back panel: Schritt 1, Bild 1 von 2 Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing back panel: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Flathead 1.5 mm Screwdriver
    $5.49
    Kaufen
    • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
  2. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing batteries: Schritt 2, Bild 1 von 1
    • Remove the 3 AAA batteries from the device.
  3. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing back half of device: Schritt 3, Bild 1 von 2 Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing back half of device: Schritt 3, Bild 2 von 2
    • Unscrew the other 4, #8 11.6 mm Phillips Head screws to remove the entire back half of the device.
    • Pull apart the device once screws are loose, splitting the device in half.
  4. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Positioning device: Schritt 4, Bild 1 von 1
    • Keeping all wires connected to their attachments, place the front half of the device face down.
  5. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Inspecting PCB: Schritt 5, Bild 1 von 1
    • Inspect the printed circuit board for any breaks or cracks.
  6. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing PCB: Schritt 6, Bild 1 von 2 Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing PCB: Schritt 6, Bild 2 von 2
    • Remove the 2, #8 11.7 mm Phillips Head screws as well as the 2, #8 7.5 mm screws on the printed circuit board.
  7. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Replacing PCB: Schritt 7, Bild 1 von 2 Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Replacing PCB: Schritt 7, Bild 2 von 2
    • Disconnect all wires from the PCB
    • Remove the damaged PCB from the microphone
    • Place new PCB in the Justin Bieber Concert Microphone.
    • Connect all the wires to the new PCB using this soldering guide.
Abschluss
Mike Seyman
437 Reputation
4 Anleitungen geschrieben
Baylor, Team 4-1, Williams Fall 2014 Mitglied von Baylor, Team 4-1, Williams Fall 2014
BU-WILLIAMS-F14S4G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 318
