Einleitung
Use this guide to remove and replace the water heater on the Karcher Carpet Cleaner 10066730.
Note: Before beginning repairs, disconnect the device from power, disconnect all hoses, drain and depressurize the system, and let the device cool if the heater was recently used.
Was du brauchst
Lower the device down so it is laying on its backside, bottom facing out.
Lower the base down until the swivel wheels touch the ground.
Use an 11 mm socket to remove the nut and washer securing the hose retainer clamps.
Use a pair of flush cutters or sharp scissors to cut the zip tie securing the two hoses together.
Pull the hose retaining clamps off of the bolt they were secured by.
Use a crescent wrench to loosen the 11/16 inch water output hose fitting on the heater.
Use a crescent wrench to loosen the 9/16 inch water input hose fitting on the heater.
Use a large flathead screwdriver to loosen the pie clamps securing the heater.
Grip the black ground jumper wire by its blue connector and pull directly away from the heater to remove it.
Remove the other side of the black ground jumper wire.
Grip the tan power wire by its blue connector and pull directly away from the heater to remove it.
Grip the brown intermittent power wire by its blue connector and pull directly away from the heater to remove it.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
