Einleitung
Use this guide to remove or replace one of the two vacuum motors on the Karcher Carpet Cleaner 10066730.
Follow this same procedure to remove the opposite vacuum motor.
Note: Before beginning repairs, disconnect the device from power, disconnect all hoses, drain and depressurize the system, and let the device cool if the heater was recently used.
Was du brauchst
Lower the device down so it is laying on its backside, bottom facing out.
Lower the base down until the swivel wheels touch the ground.
Use a 7/16 inch socket and wrench to remove the four bolts, nuts, and washers securing the vacuum motor cover to the base.
Use a Phillips screwdriver to remove the screw securing the ground wire to the vacuum motor.
Separate the purple wire from the left black wire.
Separate the white wire from the right black wire.
Use a Phillips screwdriver to remove the two screws securing the motor fan blade cover.
Use a Phillips screwdriver to remove the four screws and washers securing the vacuum motor mount.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
