Einleitung
In this guide, you will replace the water sensor. This is necessary if the sensor is faulty and doesn't accurately read the amount of water in the Water Reservoir.
Was du brauchst
Lift the Water Reservoir up. It should be easy to separate it from the main part of the brewer.
Using the Phillips #1 screwdriver, remove the six 140mm screws from the bottom of the Keurig machine.
Use the metal spudger to separate the silver panel on the right side of the Keurig machine.
Tilt the brewer upside down and grab the bottom of the silver panel
Using your hands, peel off the silver panel from the Keurig machine.
With one hand, place one finger inside the frame where the silver panel was attached and hold the base.
With the other hand, pull down to pop out the front housing of the Keurig machine.
Using your hands, pry the back exterior of the brewer from the right side of the Keurig.
Use the blue opening tool to separate the top right silver panel from the back exterior.
Use the Phillips #1 screwdriver to remove the 120mm screw located on the top left corner from the side of the brewer where the water reservoir was.
Use the Phillips #1 screwdriver to remove another 120mm screw located under the end of the empty slot running across the left side of the Keurig.
Separate the side panel from the top frame of the brewer, using the blue opening tool for help if necessary.
Place the brewer on its side as shown in the picture
Using the metal spudger, pry away the housing surrounding the sides of the Keurig machine from the bottom.
Work your way around the perimeter of the base.
Remove the entire back exterior surrounding the Keurig by removing the latches connecting the back exterior to the silver frame on top. To do this, use the metal spudger to lift the latches up and out.
Reorient the brewer as shown in the picture.
Locate the four 140mm screws holding the top frame of the Keurig in place. Remove these screws using the Phillips #1 screwdriver.
Two of the screws are on the inside of the frame close to the water heater.
The other two screws are located on the outside of the frame.
Remove the top of the framing that encases the circuit board.
Remove the wires that are connected to the top of the circuit board.
Pull out the multicolored wires by their bases.
The bundle with black wires and one red wire is connected to the very top of the circuit board. To remove these wires, squeeze in the white tabs as you pull them out.
Using the metal spudger, snap the circuit board out of the latches on the bottom of the board.
Unplug the rest of the wires connecting to the circuit board by pulling them out by their bases.
Remove the circuit board from the device.
Pull out the white tab that has the wires that connect the Water Sensor to the water pump.
Pry the water sensor out of the frame on the base of the brewer and remove it from the device.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
Can I buy a replacement water sensor directly from you? If not, where can I buy one?
