Zum Hauptinhalt wechseln
Kinivo ZX100 Mini Portable Speaker Replacement
Was du brauchst
  1. Kinivo ZX100 Mini Portable Speaker Replacement, Disassembling Kinivo ZX100 Mini Portable Speaker: Schritt 1, Bild 1 von 1
    • Open the circular portion at the top of the speaker by twisting it until it reaches the maximum possible height.
    • Make sure it is twisted fully, as this will allow access to four screws to be removed in the next step.
  2. Kinivo ZX100 Mini Portable Speaker Replacement: Schritt 2, Bild 1 von 2 Kinivo ZX100 Mini Portable Speaker Replacement: Schritt 2, Bild 2 von 2
    • Remove the four 12 mm Phillips screws from the enclosure.
  3. Kinivo ZX100 Mini Portable Speaker Replacement: Schritt 3, Bild 1 von 2 Kinivo ZX100 Mini Portable Speaker Replacement: Schritt 3, Bild 2 von 2
    • Separate the resonator portion from the base of device to reveal the middle separator of the enclosure. The enclosure will now be in two pieces.
    • Hold the resonator portion of the enclosure gently aside to make sure there is no tension on the black and red wires coming from the bottom portion of the device.
    • Excessive force may disconnect the black and red speaker wires from the circuitry in the bottom portion of the device.
  4. Kinivo ZX100 Mini Portable Speaker Replacement: Schritt 4, Bild 1 von 1
    • Separate the very bottom portion of the enclosure (marked in red) by pulling vertically on the red portion of the enclosure (marked in orange).
    • Gently set the very bottom portion and the resonator section aside once they have both been separated.
    • Remove the circuit board with your hands by lifting and sliding the board away from the LED indicator.
  5. Kinivo ZX100 Mini Portable Speaker Replacement, Speaker: Schritt 5, Bild 1 von 1
    • Desolder both wired connections.
    • Once the solder has melted, the wires should be easily pulled off the circuit board.
    • Be sure to connect the black wire to SPK- and the red wire to SPK+ when soldering the wires back onto the circuit board.
Abschluss
Test the speaker once you’ve reassembled it. Sound should now play properly on your Kinivo ZX100 Mini Portable Speaker.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Justin DaRosa
146 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 1-5, Shastany Spring 2015 Mitglied von UMass Dartmouth, Team 1-5, Shastany Spring 2015
UMASSD-SHASTANY-S15S1G5
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 448
