Zum Hauptinhalt wechseln
Kocaso M750B Speaker Replacement
Was du brauchst
  1. Kocaso M750B Speaker Replacement, Backplate: Schritt 1, Bild 1 von 3 Kocaso M750B Speaker Replacement, Backplate: Schritt 1, Bild 2 von 3 Kocaso M750B Speaker Replacement, Backplate: Schritt 1, Bild 3 von 3
    • Pry the edges of the tablet apart using an iFixit opening tool.
  2. Kocaso M750B Speaker Replacement, Speaker: Schritt 2, Bild 1 von 2 Kocaso M750B Speaker Replacement, Speaker: Schritt 2, Bild 2 von 2
    • Insert a spudger into the mesh that holds the speaker.
    • Press around the mesh lightly until the speaker comes loose.
  3. Kocaso M750B Speaker Replacement: Schritt 3, Bild 1 von 2 Kocaso M750B Speaker Replacement: Schritt 3, Bild 2 von 2
    • Desolder the solder joints that connect the motherboard to the speaker.
    • The solder joints are connected to one red and one black cable.
    • When using the soldering iron, make sure to review the safety guidelines provided in the introduction. Work carefully and precisely to avoid any electrical discharge, puncture of the battery, or heating of the motherboard.
Abschluss
Steven Musser
88 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 57
