Zum Hauptinhalt wechseln
Kodak Easyshare C813 Memory Card Replacement
  1. Kodak Easyshare C813 Memory Card Replacement, Memory Card: Schritt 1, Bild 1 von 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the mode selector dial.
  2. Kodak Easyshare C813 Memory Card Replacement: Schritt 2, Bild 1 von 3 Kodak Easyshare C813 Memory Card Replacement: Schritt 2, Bild 2 von 3 Kodak Easyshare C813 Memory Card Replacement: Schritt 2, Bild 3 von 3
    • Locate battery compartment on bottom of camera and slide open by applying pressure in the direction of the arrow.
  3. Kodak Easyshare C813 Memory Card Replacement: Schritt 3, Bild 1 von 2 Kodak Easyshare C813 Memory Card Replacement: Schritt 3, Bild 2 von 2
    • Locate memory card slot and insert memory card by inserting the gold terminals first.
    • Apply pressure into you feel it lock into place.
    • Note: To remove a memory card, apply pressure down until you feel it click. Then it should pop up and you can just pull it up.
  4. Kodak Easyshare C813 Memory Card Replacement: Schritt 4, Bild 1 von 2 Kodak Easyshare C813 Memory Card Replacement: Schritt 4, Bild 2 von 2
    • Return the battery door to its formerly closed position.
  5. Kodak Easyshare C813 Memory Card Replacement: Schritt 5, Bild 1 von 1
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 24-22, Regan Spring 2010 Mitglied von Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 19
Letzte 30 Tage: 101
Insgesamt: 9,619
