Zum Hauptinhalt wechseln
Kodak PixPro AZ251 LCD Screen Replacement
Was du brauchst
  1. Kodak PixPro AZ251 LCD Screen Replacement, Batteries: Schritt 1, Bild 1 von 2 Kodak PixPro AZ251 LCD Screen Replacement, Batteries: Schritt 1, Bild 2 von 2
    • Slide switch to open lock position.
  2. Kodak PixPro AZ251 LCD Screen Replacement: Schritt 2, Bild 1 von 2 Kodak PixPro AZ251 LCD Screen Replacement: Schritt 2, Bild 2 von 2
    • Press down on the battery cover and slide outwards to open.
  3. Kodak PixPro AZ251 LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Remove the batteries.
  4. Kodak PixPro AZ251 LCD Screen Replacement, Back Cover: Schritt 4, Bild 1 von 3 Kodak PixPro AZ251 LCD Screen Replacement, Back Cover: Schritt 4, Bild 2 von 3 Kodak PixPro AZ251 LCD Screen Replacement, Back Cover: Schritt 4, Bild 3 von 3
    • Remove a total of four 5mm JIS #000 screws from around the camera:
    • Two screws from the right side.
    • Two screws from the left side.
  5. Kodak PixPro AZ251 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Remove the single 5mm Phillips #00 screw from the bottom.
  6. Kodak PixPro AZ251 LCD Screen Replacement: Schritt 6, Bild 1 von 2 Kodak PixPro AZ251 LCD Screen Replacement: Schritt 6, Bild 2 von 2
    • Open the flash module.
    • Remove the two 6mm JIS #00 screws found inside of the flash housing.
  7. Kodak PixPro AZ251 LCD Screen Replacement: Schritt 7, Bild 1 von 3 Kodak PixPro AZ251 LCD Screen Replacement: Schritt 7, Bild 2 von 3 Kodak PixPro AZ251 LCD Screen Replacement: Schritt 7, Bild 3 von 3
    • Use a plastic opening tool to pry apart both halves of the camera.
    • Remove the back panel.
  8. Kodak PixPro AZ251 LCD Screen Replacement, LCD Screen: Schritt 8, Bild 1 von 2 Kodak PixPro AZ251 LCD Screen Replacement, LCD Screen: Schritt 8, Bild 2 von 2
    • Remove these three JIS #000 screws from the control board:
    • 5mm screw.
    • 4mm screw.
    • 2mm screw.
  9. Kodak PixPro AZ251 LCD Screen Replacement: Schritt 9, Bild 1 von 1
    • Pull the small metal switch plate to the side.
  10. Kodak PixPro AZ251 LCD Screen Replacement: Schritt 10, Bild 1 von 2 Kodak PixPro AZ251 LCD Screen Replacement: Schritt 10, Bild 2 von 2
    • Pry the LCD screen out of the metal housing plate with a plastic opening tool.
  11. Kodak PixPro AZ251 LCD Screen Replacement: Schritt 11, Bild 1 von 2 Kodak PixPro AZ251 LCD Screen Replacement: Schritt 11, Bild 2 von 2
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Pull the orange cable out of the socket.
Abschluss
USF Tampa, Team S1-G1, Cagle Spring 2018 Mitglied von USF Tampa, Team S1-G1, Cagle Spring 2018
USFT-CAGLE-S18S1G1
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 32
Insgesamt: 1,572
