Zum Hauptinhalt wechseln
Einleitung
In this guide, you will learn how to remove and replace the motherboard of your Kodak PixPro AZ251. Replacing the motherboard may be necessary if your camera does not turn on and you already tried replacing the batteries. For this replacement guide you should be comfortable using a soldering iron.
  1. Kodak PixPro AZ251 Motherboard Replacement, Batteries: Schritt 1, Bild 1 von 2 Kodak PixPro AZ251 Motherboard Replacement, Batteries: Schritt 1, Bild 2 von 2
    • Slide switch to open lock position.
  2. Kodak PixPro AZ251 Motherboard Replacement: Schritt 2, Bild 1 von 2 Kodak PixPro AZ251 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Press down on the battery cover and slide outwards to open.
  3. Kodak PixPro AZ251 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the batteries.
  4. Kodak PixPro AZ251 Motherboard Replacement, Back Cover: Schritt 4, Bild 1 von 3 Kodak PixPro AZ251 Motherboard Replacement, Back Cover: Schritt 4, Bild 2 von 3 Kodak PixPro AZ251 Motherboard Replacement, Back Cover: Schritt 4, Bild 3 von 3
    • Remove a total of four 5mm JIS #000 screws from around the camera:
    • Two screws from the right side.
    • Two screws from the left side.
  5. Kodak PixPro AZ251 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the single 5mm Phillips #00 screw from the bottom.
  6. Kodak PixPro AZ251 Motherboard Replacement: Schritt 6, Bild 1 von 2 Kodak PixPro AZ251 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Open the flash module.
    • Remove the two 6mm JIS #00 screws found inside of the flash housing.
  7. Kodak PixPro AZ251 Motherboard Replacement: Schritt 7, Bild 1 von 3 Kodak PixPro AZ251 Motherboard Replacement: Schritt 7, Bild 2 von 3 Kodak PixPro AZ251 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Use a plastic opening tool to pry apart both halves of the camera.
    • Remove the back panel.
  8. Kodak PixPro AZ251 Motherboard Replacement, LCD Screen: Schritt 8, Bild 1 von 2 Kodak PixPro AZ251 Motherboard Replacement, LCD Screen: Schritt 8, Bild 2 von 2
    • Remove these three JIS #000 screws from the control board:
    • 5mm screw.
    • 4mm screw.
    • 2mm screw.
  9. Kodak PixPro AZ251 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Pull the small metal switch plate to the side.
  10. Kodak PixPro AZ251 Motherboard Replacement: Schritt 10, Bild 1 von 2 Kodak PixPro AZ251 Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Pry the LCD screen out of the metal housing plate with a plastic opening tool.
  11. Kodak PixPro AZ251 Motherboard Replacement: Schritt 11, Bild 1 von 2 Kodak PixPro AZ251 Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Pull the orange cable out of the socket.
  12. Kodak PixPro AZ251 Motherboard Replacement, Motherboard: Schritt 12, Bild 1 von 2 Kodak PixPro AZ251 Motherboard Replacement, Motherboard: Schritt 12, Bild 2 von 2
    • Remove three 4mm JIS #000 screws from the metal housing plate.
  13. Kodak PixPro AZ251 Motherboard Replacement: Schritt 13, Bild 1 von 1
    • Lift the metal housing plate out using your hands.
  14. Kodak PixPro AZ251 Motherboard Replacement: Schritt 14, Bild 1 von 1
    • Disconnect the orange cable, connecting the small metal switch plate to the motherboard, by pulling it outwards with tweezers.
  15. Kodak PixPro AZ251 Motherboard Replacement: Schritt 15, Bild 1 von 2 Kodak PixPro AZ251 Motherboard Replacement: Schritt 15, Bild 2 von 2
    • Disconnect two orange cables, one at the top and the other at the bottom of the motherboard, by pulling them outwards with tweezers.
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF socket.
  16. Kodak PixPro AZ251 Motherboard Replacement: Schritt 16, Bild 1 von 2 Kodak PixPro AZ251 Motherboard Replacement: Schritt 16, Bild 2 von 2
    • Remove the rectangular black cushion pad on the bottom left of the motherboard by pulling it upwards with your hands.
    • Disconnect the orange cable by pulling it outwards with tweezers.
  17. Kodak PixPro AZ251 Motherboard Replacement: Schritt 17, Bild 1 von 1
    • Remove the two 4mm JIS #000 screws from the motherboard.
  18. Kodak PixPro AZ251 Motherboard Replacement: Schritt 18, Bild 1 von 1
    • Desolder two pairs of electrical cable connections on the top left of the motherboard using the soldering iron.
    • Desolder the metal connector joining the two parts of the motherboard using the soldering iron.
    • The unsoldering steps are not shown.
  19. Kodak PixPro AZ251 Motherboard Replacement: Schritt 19, Bild 1 von 1
    • Lift the motherboard up using your hands.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S1-G1, Cagle Spring 2018 Mitglied von USF Tampa, Team S1-G1, Cagle Spring 2018
USFT-CAGLE-S18S1G1
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 23
Insgesamt: 958
