Zum Hauptinhalt wechseln
Kurio Touch 4S Battery Replacement
Was du brauchst
  1. Kurio Touch 4S Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Battery Replacement: Schritt 2, Bild 1 von 3 Kurio Touch 4S Battery Replacement: Schritt 2, Bild 2 von 3 Kurio Touch 4S Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove back cover by prying away from the device.
    • The easiest place to remove the cover is from the bottom and top, then try to open it from the right and left sides.
    • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
  3. Kurio Touch 4S Battery Replacement: Schritt 3, Bild 1 von 3 Kurio Touch 4S Battery Replacement: Schritt 3, Bild 2 von 3 Kurio Touch 4S Battery Replacement: Schritt 3, Bild 3 von 3
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver.
  4. Kurio Touch 4S Battery Replacement: Schritt 4, Bild 1 von 1
    • After you remove your four screws use your plastic opening tool to help you open the plastic cover of your device.
  5. Kurio Touch 4S Battery Replacement: Schritt 5, Bild 1 von 1
    • Use the plastic opening tool to remove the battery from its place.
    • The battery is glued into the device. So try removing it gently.
  6. Kurio Touch 4S Battery Replacement: Schritt 6, Bild 1 von 1
    • Remove the two wires using soldering tool to detach your bad battery from the device .
    • Gently remove the wires one by one. Do not damage the head that is glued into the motherboard.
    • For more information on how to solder and desolder the wire Click here
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 6-5, Brown Winter 2015 Mitglied von USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
do you know where to buy a replacement battery ?
Phil Bowring - Antwort
Any idea where I can purchase a replacement battery?
Brooke Lonsdale - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 1,601
