Zum Hauptinhalt wechseln
Kurio Touch 4S Speaker Replacement
Was du brauchst
  1. Kurio Touch 4S Speaker  Replacement, Speakers: Schritt 1, Bild 1 von 1
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Speaker  Replacement: Schritt 2, Bild 1 von 3 Kurio Touch 4S Speaker  Replacement: Schritt 2, Bild 2 von 3 Kurio Touch 4S Speaker  Replacement: Schritt 2, Bild 3 von 3
    • Remove back cover by prying away from the device.
    • The easiest place to remove the cover is from the bottom and top; try to open it from the right and left sides.
    • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
  3. Kurio Touch 4S Speaker  Replacement: Schritt 3, Bild 1 von 2 Kurio Touch 4S Speaker  Replacement: Schritt 3, Bild 2 von 2
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver
    • After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
  4. Kurio Touch 4S Speaker  Replacement: Schritt 4, Bild 1 von 1
  5. Kurio Touch 4S Speaker  Replacement: Schritt 5, Bild 1 von 1
    • Gently remove the plastic cover that is covering the camera.
  6. Kurio Touch 4S Speaker  Replacement: Schritt 6, Bild 1 von 1
    • Separate the two halves of your Kurio Touch 4S and lay them besides each other.
  7. Kurio Touch 4S Speaker  Replacement: Schritt 7, Bild 1 von 1
    • Use the soldering tool to detach the speaker wires.
    • For more information on how to solder the wires Click here
  8. Kurio Touch 4S Speaker  Replacement: Schritt 8, Bild 1 von 1
    • Press the speaker in the manner shown so that it comes out of its slot.
    • Be sure not to apply too much force or you can break the back cover.
  9. Kurio Touch 4S Speaker  Replacement: Schritt 9, Bild 1 von 1
    • Use the Tweezers to remove the speaker from its place.
    • Remove the speaker gently.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Moin Khan
234 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 6-5, Brown Winter 2015 Mitglied von USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 164
