Einleitung
This guide walks you through replacing the display connector on the LG Chocolate 3 (VX8560). If the screen is malfunctioning due to a loose or damaged connector, following this guide will help you restore functionality.
The display connector links the phone's screen to the motherboard, transmitting visual data. A faulty connector can cause the screen to have a blank display or the screen to flicker.
Important Safety and Handling Information:
- Power off and battery removal: before beginning, turn off the device and remove the battery to prevent electrical damage
- Careful Handling of small parts: the display connector can be fragile; avoid applying excessive force when reconnecting
Was du brauchst
Remove the battery and expose the motherboard following the General Disassembly LG VX8560. Keep in mind that you will need to reinstall the side keys after completing this repair.
Next, locate the intertwined blue and red wire; this is the display connector that links the screen to the motherboard.
Skip this step if the screen display connector is already detached from the motherboard. Using a spudger, insert the pointed end between the plastic end of the wire and the motherboard socket, then carefully lift or push the wire to disconnect it. You should see two golden pins protruding from the plastic connector.
To reconnect, align the two golden pins with their corresponding socket on the motherboard and gently press down until you hear a click indicating a secure connection.
To reassemble your device, follow the Side Keys Installation guide in reverse order.
