Was du brauchst
Shutdown your phone.
Remove the back cover of the phone
Unscrew all the screws identified in red in the picture.
Remove the plastic covers using your fingernails or a plastic tool.
Carefully peel off the 3 metal stickers (connectors) identified in white on the photo with a flat screwdriver.
Cut pieces of a sheet of cardboard or a sheet thick enough to the size of the stickers.
Glue a piece of cardboard or thick paper under each sticker to create extra thickness.
Replace the stickers in their original location (they will no longer stick to the shell, but that's okay).
Reassemble the phone by repeating the previous steps, taking care to tighten the screws properly when reassembling
To reassemble your device, follow the instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
100%
Hier starten ›
