Einleitung
Use this guide to replace the headphone jack in your LG G3 Vigor.
Was du brauchst
Remove the battery by lifting from the slot at the bottom of the battery.
Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
Remove the front camera.
Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
Use the pointed end of a spudger to push back the two motherboard retaining flaps.
The motherboard should now be able to be lifted out of the device.
Remove the headphone jack by inserting the spudger into the jack and pulling it up and out.
2 weitere Personen haben diese Anleitung absolviert.
