Zum Hauptinhalt wechseln
LG G8 ThinQ Front Cameras Replacement
Was du brauchst
  1. LG G8 ThinQ Front Cameras Replacement, SIM Card Tray: Schritt 1, Bild 1 von 3 LG G8 ThinQ Front Cameras Replacement, SIM Card Tray: Schritt 1, Bild 2 von 3 LG G8 ThinQ Front Cameras Replacement, SIM Card Tray: Schritt 1, Bild 3 von 3
    • Unplug and power off your phone before you begin.
    • Insert the SIM card eject tool into the pinhole in the lower right side of the phone.
    • Remove the SIM card and tray.
  2. LG G8 ThinQ Front Cameras Replacement, Back Panel: Schritt 2, Bild 1 von 3 LG G8 ThinQ Front Cameras Replacement, Back Panel: Schritt 2, Bild 2 von 3 LG G8 ThinQ Front Cameras Replacement, Back Panel: Schritt 2, Bild 3 von 3
    • Place the phone so that the screen is facing down.
    • Insert opening cards between the back panel and frame of the phone to loosen the clips and adhesive.
    • Using equal pressure, carefully pry the back panel away from the phone.
    • Once enough space has been created, use an opening tool to completely separate the back panel from the phone.
  3. LG G8 ThinQ Front Cameras Replacement, Midframe: Schritt 3, Bild 1 von 3 LG G8 ThinQ Front Cameras Replacement, Midframe: Schritt 3, Bild 2 von 3 LG G8 ThinQ Front Cameras Replacement, Midframe: Schritt 3, Bild 3 von 3
    • Remove all 14 screws from the midframe using a Phillips #000 screwdriver.
    • Work an opening tool around the perimeter of the midframe to pry and remove it from the phone.
  4. LG G8 ThinQ Front Cameras Replacement, Front Cameras: Schritt 4, Bild 1 von 2 LG G8 ThinQ Front Cameras Replacement, Front Cameras: Schritt 4, Bild 2 von 2
    • Using an opening tool, carefully disconnect the ribbon cables from both cameras.
  5. LG G8 ThinQ Front Cameras Replacement: Schritt 5, Bild 1 von 3 LG G8 ThinQ Front Cameras Replacement: Schritt 5, Bild 2 von 3 LG G8 ThinQ Front Cameras Replacement: Schritt 5, Bild 3 von 3
    • Using an opening tool, carefully pry up and remove both cameras from the phone casing.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Josh Cress
458 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 14
Insgesamt: 431
