Zum Hauptinhalt wechseln
LG V50 ThinQ Battery Replacement
Was du brauchst
  1. LG V50 ThinQ Battery Replacement, Battery: Schritt 1, Bild 1 von 3 LG V50 ThinQ Battery Replacement, Battery: Schritt 1, Bild 2 von 3 LG V50 ThinQ Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Flip the phone over, so that the back of the phone is facing you.
    • Using an opening pick, pry open the back cover of the phone by moving the opening pick along all sides to reveal the internal components.
  2. LG V50 ThinQ Battery Replacement: Schritt 2, Bild 1 von 3 LG V50 ThinQ Battery Replacement: Schritt 2, Bild 2 von 3 LG V50 ThinQ Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove all twelve 1 mm Phillips #000 screws.
    • Remember to keep the screws in a safe place for reassembly later!
  3. LG V50 ThinQ Battery Replacement: Schritt 3, Bild 1 von 3 LG V50 ThinQ Battery Replacement: Schritt 3, Bild 2 von 3 LG V50 ThinQ Battery Replacement: Schritt 3, Bild 3 von 3
    • Remove the two brackets.
  4. LG V50 ThinQ Battery Replacement: Schritt 4, Bild 1 von 2 LG V50 ThinQ Battery Replacement: Schritt 4, Bild 2 von 2
    • DO NOT attempt to remove the phone battery with a metallic/sharp prying object.
    • Disconnect the battery from the phone by removing the battery connection from the connector port.
    • Remove the battery by prying the underside of the battery and pulling upwards with the opening pick (shown in image 2).
    • Do not be too rough with the battery, as it is easy to dent/break into.
    • Now, place the new battery inside the slot, firmly pressing it into the space against the copper-colored heatsink on the bottom.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023 Mitglied von UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 33
Letzte 30 Tage: 147
Insgesamt: 683
