Zum Hauptinhalt wechseln
LG V50 ThinQ Motherboard Replacement
Was du brauchst
  1. LG V50 ThinQ Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 3 LG V50 ThinQ Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 3 LG V50 ThinQ Motherboard Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Flip the phone over, so that the back of the phone is facing you.
    • Using an opening pick, pry open the back cover of the phone by moving the opening pick along all sides to reveal the internal components.
  2. LG V50 ThinQ Motherboard Replacement: Schritt 2, Bild 1 von 3 LG V50 ThinQ Motherboard Replacement: Schritt 2, Bild 2 von 3 LG V50 ThinQ Motherboard Replacement: Schritt 2, Bild 3 von 3
    • With the back side open, unscrew all the 1 mm Phillips #000 screws.
    • Remember to keep the screws in a safe place for reassembly later!
  3. LG V50 ThinQ Motherboard Replacement: Schritt 3, Bild 1 von 3 LG V50 ThinQ Motherboard Replacement: Schritt 3, Bild 2 von 3 LG V50 ThinQ Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Take out the two brackets that are covering the internal components.
  4. LG V50 ThinQ Motherboard Replacement: Schritt 4, Bild 1 von 3 LG V50 ThinQ Motherboard Replacement: Schritt 4, Bild 2 von 3 LG V50 ThinQ Motherboard Replacement: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the battery connection from its connector port, located above the battery.
    • Similarly, remove the screen connection from its connector port, found on the left side of the back of the device.
    • Pull up with tweezers on the dark orange cable to disconnect it.
  5. LG V50 ThinQ Motherboard Replacement: Schritt 5, Bild 1 von 3 LG V50 ThinQ Motherboard Replacement: Schritt 5, Bild 2 von 3 LG V50 ThinQ Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Disconnect the orange cable by pulling the connector piece up with your fingers
    • Pull up with tweezers on the end of the white wire to disconnect it from the motherboard
    • Using the metal spudger, pull up from below the motherboard at the top of the phone and near the battery to remove the motherboard from the phone.
Abschluss
UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023 Mitglied von UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 21
Insgesamt: 186
