Zum Hauptinhalt wechseln
LG V50 ThinQ Screen Replacement
Was du brauchst
  1. LG V50 ThinQ Screen Replacement, Screen: Schritt 1, Bild 1 von 3 LG V50 ThinQ Screen Replacement, Screen: Schritt 1, Bild 2 von 3 LG V50 ThinQ Screen Replacement, Screen: Schritt 1, Bild 3 von 3
    • Flip the phone over, making sure that the back of the phone is facing up.
    • With an opening pick, run the tool along the edge of the back cover of the phone and carefully pry it open.
  2. LG V50 ThinQ Screen Replacement: Schritt 2, Bild 1 von 2 LG V50 ThinQ Screen Replacement: Schritt 2, Bild 2 von 2
    • With the device facing down, remove all 12 1mm Phillips #000 screws.
    • Keep in mind that the screws must be reused at the end of the guide to put the phone back together.
  3. LG V50 ThinQ Screen Replacement: Schritt 3, Bild 1 von 3 LG V50 ThinQ Screen Replacement: Schritt 3, Bild 2 von 3 LG V50 ThinQ Screen Replacement: Schritt 3, Bild 3 von 3
    • Remove the two brackets covering the internal components.
  4. LG V50 ThinQ Screen Replacement: Schritt 4, Bild 1 von 2 LG V50 ThinQ Screen Replacement: Schritt 4, Bild 2 von 2
    • Remove the battery connection from its connector port, located above the battery.
    • Similarly, remove the screen connection from its connector port, found on the left side of the back of the device.
  5. LG V50 ThinQ Screen Replacement: Schritt 5, Bild 1 von 1
    • With an opening pick (or a similar tool that isn't sharp), run the tool along the edge between the screen and the base of the phone.
    • After the screen is removed from the device, use a 1mm double-sided adhesive along the edges of the phone.
    • Carefully put the replacement screen into place.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Carlos Rivera
121 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023 Mitglied von UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 58
Insgesamt: 396
