Einleitung
If the outer plastic casing of the phone is damaged, it can easily be replaced with these steps.
Was du brauchst
Hold the phone case in your palm and slide the back cover towards yourself using your thumb
Slide a tool or finger into the notch at the top of the battery to carefully remove it.
Take the Philips screwdriver and unscrew the four visible screws on the backside of the phone indicated by the four red circles.
Then, take the pointed end of a spudger and pry out the rubber stopper to reveal the last screw at the top indicated with the blue circle.
Lay out and organize the parts of the phone. You can now put the inner parts of the phone into the new case.
