Einleitung
This guide will instruct you how to replace the motherboard cushions of an LG Chocolate 3 Flip-phone (LG VX8560). There are no special skills required for this project, but be prepared to handle small screws and parts of the phone.
The motherboard is the “heart” of the phone. It connects all other parts of the phone together that help perform tasks. The cushions are what keep the motherboard separate from other parts of the phone, that way it does not get scratched or damaged.
Before beginning, make sure to power off your device.
Was du brauchst
In order to disassemble the phone, you will need to follow the General Disassembly LG VX8560 first.
Locate the cushions, which should be in the corners of the motherboard.
Gently but firmly remove the old cushions with a pair of tweezers.
Replace the cushions with new ones using tweezers.
To reassemble your device, follow the General Disassembly LG VX 8560 guide.
