Zum Hauptinhalt wechseln
LG X Power Charging Port Replacement
Was du brauchst
  1. LG X Power Charging Port Replacement, LG X Power Disassembly: Schritt 1, Bild 1 von 2 LG X Power Charging Port Replacement, LG X Power Disassembly: Schritt 1, Bild 2 von 2
    • Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
  2. LG X Power Charging Port Replacement: Schritt 2, Bild 1 von 2 LG X Power Charging Port Replacement: Schritt 2, Bild 2 von 2
    • Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
  3. LG X Power Charging Port Replacement: Schritt 3, Bild 1 von 2 LG X Power Charging Port Replacement: Schritt 3, Bild 2 von 2
    • Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
    • With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
  4. LG X Power Charging Port Replacement, Charging Port: Schritt 4, Bild 1 von 3 LG X Power Charging Port Replacement, Charging Port: Schritt 4, Bild 2 von 3 LG X Power Charging Port Replacement, Charging Port: Schritt 4, Bild 3 von 3
    • Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
    • Pull the cameras out to remove them.
  5. LG X Power Charging Port Replacement: Schritt 5, Bild 1 von 1
    • Use the flat end of a spudger to disconnect the battery from the motherboard.
    • You will not be removing anything, just disconnecting.
  6. LG X Power Charging Port Replacement: Schritt 6, Bild 1 von 1
    • Insert a plastic opening tool underneath the motherboard and pry upwards to remove it.
  7. LG X Power Charging Port Replacement: Schritt 7, Bild 1 von 1
    • Desolder the MicroUSB charging port from the motherboard.
    • If you need help soldering, follow this guide.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Chad Sears
1.149 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S3-G6, Nance Spring 2018 Mitglied von USF Tampa, Team S3-G6, Nance Spring 2018
USFT-NANCE-S18S3G6
3 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Where can i get the charging port part? There are so many different usb female ports.
Wayne Newell - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 5,918
