Zum Hauptinhalt wechseln
Lasko CD08200 Fan Replacement
Was du brauchst
  1. Lasko CD08200 Fan Replacement, Lasko CD08200 Disassembly: Schritt 1, Bild 1 von 2 Lasko CD08200 Fan Replacement, Lasko CD08200 Disassembly: Schritt 1, Bild 2 von 2
    • Turn over the device and place it on its head.
    • Remove the four 14mm screws holding the bottom using a TR15 screwdriver.
  2. Lasko CD08200 Fan Replacement: Schritt 2, Bild 1 von 1
    • Remove both 14mm screws from the power cord casing using a Phillips #2 screwdriver.
    • Remove the power cord casing from the device case.
  3. Lasko CD08200 Fan Replacement: Schritt 3, Bild 1 von 3 Lasko CD08200 Fan Replacement: Schritt 3, Bild 2 von 3 Lasko CD08200 Fan Replacement: Schritt 3, Bild 3 von 3
    • Cut the sticker on the right side of the device using a Jimmy.
    • Unscrew the four 14mm screws with a Phillips #2 bit on the back of the device.
    • If your screwdriver cannot reach the screw, you can use the metal spudger.
    • Remove the back casing from the device.
  4. Lasko CD08200 Fan Replacement: Schritt 4, Bild 1 von 3 Lasko CD08200 Fan Replacement: Schritt 4, Bild 2 von 3 Lasko CD08200 Fan Replacement: Schritt 4, Bild 3 von 3
    • Remove the four 14mm screws housing the fan using the Phillips #2 screwdriver.
    • Remove the top of the fan housing with the fan attached and place it on the table.
  5. Lasko CD08200 Fan Replacement, Fan: Schritt 5, Bild 1 von 2 Lasko CD08200 Fan Replacement, Fan: Schritt 5, Bild 2 von 2
    • While holding onto the back of the fan housing with one hand and holding the center of the propeller, pull the propeller out.
    • During reassembly, push the propeller and red plate together into the metal shaft until you feel the plate click.
Abschluss
York University, Team S1-G1, Woodhouse Winter 2020 Mitglied von York University, Team S1-G1, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S1G1
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 670
