Zum Hauptinhalt wechseln
LeapFrog LeapPad Ultra XDi Home Button Replacement
Was du brauchst
  1. LeapFrog LeapPad Ultra XDi Home Button Replacement, Battery: Schritt 1, Bild 1 von 2 LeapFrog LeapPad Ultra XDi Home Button Replacement, Battery: Schritt 1, Bild 2 von 2
    • Orient the tablet so it’s laying screen down and the barcode sticker is facing up.
    • Remove the barcode sticker to expose the two screws.
  2. LeapFrog LeapPad Ultra XDi Home Button Replacement: Schritt 2, Bild 1 von 2 LeapFrog LeapPad Ultra XDi Home Button Replacement: Schritt 2, Bild 2 von 2
    • Remove the two 5.0mm Phillips #0 screws.
  3. LeapFrog LeapPad Ultra XDi Home Button Replacement: Schritt 3, Bild 1 von 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: Schritt 3, Bild 2 von 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: Schritt 3, Bild 3 von 3
    • Using the iFixit opening tool, pry off the purple and white child-proof casing to expose the twelve screws.
  4. LeapFrog LeapPad Ultra XDi Home Button Replacement: Schritt 4, Bild 1 von 2 LeapFrog LeapPad Ultra XDi Home Button Replacement: Schritt 4, Bild 2 von 2
    • Remove all twelve 7mm Phillips #1 screws located along the edges of the device.
  5. LeapFrog LeapPad Ultra XDi Home Button Replacement: Schritt 5, Bild 1 von 2 LeapFrog LeapPad Ultra XDi Home Button Replacement: Schritt 5, Bild 2 von 2
    • Remove the purple case, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra XDi Home Button Replacement: Schritt 6, Bild 1 von 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: Schritt 6, Bild 2 von 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: Schritt 6, Bild 3 von 3
    • Using your fingers, grab the battery wires and carefully unplug them from the motherboard.
    • Use the Spudger to remove the glued down battery.
  7. LeapFrog LeapPad Ultra XDi Home Button Replacement, Home Button: Schritt 7, Bild 1 von 3 LeapFrog LeapPad Ultra XDi Home Button Replacement, Home Button: Schritt 7, Bild 2 von 3 LeapFrog LeapPad Ultra XDi Home Button Replacement, Home Button: Schritt 7, Bild 3 von 3
    • Locate the three ribbon cables on top of the motherboard.
    • Flip up the locking clip on the ribbon cable connector to release the cable.
    • Disconnect the cables from their connectors.
  8. LeapFrog LeapPad Ultra XDi Home Button Replacement: Schritt 8, Bild 1 von 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: Schritt 8, Bild 2 von 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: Schritt 8, Bild 3 von 3
    • Unscrew the four 5mm Phillips #1 screws.
    • Unscrew the two 5mm Phillips #1 screws.
    • Lift the home button circuit board up. Replace the home button circuit board.
    • The entire home button circuit board must be replaced.
    • Do not dispose of rubber padding on home button circuit board.
Abschluss
Mario Rivera
243 Reputation
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 8
Insgesamt: 307
