Zum Hauptinhalt wechseln
Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement
Was du brauchst
  1. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Remove nine 6 mm screws from the bottom cover of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: Schritt 2, Bild 1 von 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: Schritt 2, Bild 2 von 2
    • Remove stylus from the lower left corner of the back panel.
  3. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: Schritt 3, Bild 1 von 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: Schritt 3, Bild 2 von 2
    • Go along the edge of the back panel with an iFixit opening tool until it pops loose.
    • Remove the back panel from the laptop.
  4. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement, Battery: Schritt 4, Bild 1 von 1
    • Remove the four 4 mm Phillips #00 screws holding the battery in.
  5. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: Schritt 5, Bild 1 von 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: Schritt 5, Bild 2 von 2
    • Use the iFixit opening tool to unplug the battery from the motherboard.
    • Potential for device damage: Make sure to be gentle while removing the wire.
  6. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: Schritt 6, Bild 1 von 1
    • Remove the battery from the laptop.
  7. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement, Wi-Fi Card: Schritt 7, Bild 1 von 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement, Wi-Fi Card: Schritt 7, Bild 2 von 2
    • Remove the single 2 mm screw from the Wi-Fi card using a Phillips #00 screwdriver.
  8. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: Schritt 8, Bild 1 von 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: Schritt 8, Bild 2 von 2
    • Detach the Wi-Fi card from the motherboard using an iFixit opening tool.
  9. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: Schritt 9, Bild 1 von 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: Schritt 9, Bild 2 von 2
    • Using tweezers, disconnect the two wires from the Wi-Fi card.
    • Remove the Wi-Fi card from the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 17
Letzte 30 Tage: 39
Insgesamt: 765
