Einleitung
This guide will show you how to replace the Bluetooth 5.1 Wi-Fi card in the Lenovo 500e 2nd Gen Chromebook, model number: 81MC005AUS. The Wi-Fi card connects the laptop to the internet and other devices. If your Bluetooth or Wi-Fi is not working properly, check our troubleshooting page.
Was du brauchst
Remove nine 6 mm screws from the bottom cover of the laptop using a Phillips #0 screwdriver.
Go along the edge of the back panel with an iFixit opening tool until it pops loose.
Remove the back panel from the laptop.
Remove the single 2 mm screw from the Wi-Fi card using a Phillips #00 screwdriver.
Using tweezers, disconnect the two wires from the Wi-Fi card.
Remove the Wi-Fi card from the laptop.
