Zum Hauptinhalt wechseln
Lenovo Essential G560 Individual Keyboard Keys Replacement
  1. Lenovo Essential G560 Individual Keyboard Keys Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Lenovo Essential G560 Individual Keyboard Keys Replacement: Schritt 2, Bild 1 von 2 Lenovo Essential G560 Individual Keyboard Keys Replacement: Schritt 2, Bild 2 von 2
    • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo Essential G560 Individual Keyboard Keys Replacement: Schritt 3, Bild 1 von 1
    • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
  4. Lenovo Essential G560 Individual Keyboard Keys Replacement, Individual Keyboard Keys: Schritt 4, Bild 1 von 1
    • Place your pointer finger under the key you want to remove. For extra leverage, use the thumb and rotate the key in the manner shown.
  5. Lenovo Essential G560 Individual Keyboard Keys Replacement: Schritt 5, Bild 1 von 1
    • The key will come off with a popping sound.
    • You will now be able to see the mechanism below the key. Clean this area using compressed air, then replace the key.
Abschluss
To reassemble your keyboard, push the key back into the original spot.
8 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 18-40, Regan Winter 2013 Mitglied von Cal Poly, Team 18-40, Regan Winter 2013
CPSU-REGAN-W13S18G40
5 Mitglieder
7 Anleitungen geschrieben
2 Kommentare
I used your guide to install the key, thank you. I bought my lenovo keys from this link below
http://www.replacementlaptopkeys.com/len...
keep up the good work.
Resteasy - Antwort
Hello , you can buy single keys on this site:
http://www.laptopkey-europe.eu/
John Pohl - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 8,603
