Zum Hauptinhalt wechseln
Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement
Was du brauchst
  1. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement, Base Cover: Schritt 1, Bild 1 von 1
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: Schritt 2, Bild 1 von 1
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement, Cooling Fans: Schritt 3, Bild 1 von 3 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement, Cooling Fans: Schritt 3, Bild 2 von 3 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement, Cooling Fans: Schritt 3, Bild 3 von 3
    • Remove the six 3.5 mm screws that secure the fans in place using a Phillips #00 screwdriver.
    • Loosen the seven captive screws using a Phillips #00 screwdriver.
  4. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: Schritt 4, Bild 1 von 2 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to unwind the black and gray wires from the clips that are holding them onto the left side fan.
  5. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: Schritt 5, Bild 1 von 2 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: Schritt 5, Bild 2 von 2
    • Lift the black piece of cloth tape that secures the right side fan wires to the circuit board.
  6. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: Schritt 6, Bild 1 von 3 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: Schritt 6, Bild 2 von 3 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: Schritt 6, Bild 3 von 3
    • Use tweezers to unplug the wiring connectors that are connected to each fan.
  7. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: Schritt 7, Bild 1 von 2 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: Schritt 7, Bild 2 von 2
    • Gently remove the fans from the laptop.
    • There is thermal paste attaching the ducting of the fans that will require some careful prying.
    • When replacing the fan, reapply a pea sized amount of thermal paste to the fan ducts.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 484
