Einleitung
Use this guide to safely remove the battery from your Lenovo Ideapad.
For your safety, drain your Lenovo Ideapad's battery before you begin this procedure. A charged lithium-ion battery can create a dangerous and uncontrollable fire if accidentally punctured. If your battery is swollen, take extra precautions.
Was du brauchst
Remove the single 7 mm Phillips #1 screw securing the optical drive.
Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
Disconnect the battery connector by pulling toward the battery parallel to the motherboard.
25 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
Votre explication est très bien détaillée et très explicite. Merci beaucoup vous m'avez vraiment aidé.
I can't get past the first step...pulling out the optical card. The rest I think I can do because I have done things like this before. I unscrewed the screw bu can't pull it out.
Unclip the tiny clips from where you removed the optical card. The back will come off
