Einleitung
If your Lenovo’s Ideapad Flex 4 battery cannot hold a charge, and your laptop dies if not plugged in, use this guide to replace your battery.
Was du brauchst
Remove the nine 6 mm screws using a T5 Torx Screwdriver.
Remove the two 10 mm screws using a T5 Torx Screwdriver.
Use a plastic opening tool to carefully pry off the back cover.
Remove the back cover.
Disconnect the battery by using a plastic opening tool or your fingers to push the connector towards the battery.
2 weitere Personen haben diese Anleitung absolviert.
