Was du brauchst
Start at the microSD slot.
Use the opening pick to slide underneath the back cover of the tablet.
Slide the opening pick around the tablet until the back cover is off.
Remove yellow tape.
Use a spudger or plastic opening tool to remove the battery's ribbon cable from the motherboard.
Gently pull on the two stretch release adhesive strips. Do not pull up, pull away from battery.
Once the tabs are off, lift the battery up from the frame.
Use a Phillips #000 screwdriver to remove the two screws that secure the speaker to the motherboard.
Lift motherboard from the tablet.
Using your hand, you can separate the top speaker from the motherboard.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
